calling hython from script and get the processed data
   3685   1   0
I have a script named A which invokes hython like this
subprocess.call('path to the hython command'+' '+'path to script B'+' '+'path to hip file')
what script B contains is:
import sys
args = sys.argv
print args
try:
  hou.hipFile.load( args[1] )
except hou.LoadWarning, e:
  print e
renders = hou.node('/out').allSubChildren()
so the basic idea is to use hython to open a scene, process it, and get some info back(in my case,“renders”).
so how to get data back from subprocess.call or are there other ways to do so?
Any ideas would be appreciated !
Edited by WhimmY - Dec. 6, 2016 06:37:05
You can look into using POpen instead [stackoverflow.com]. This way you get a handle and can create a polling loop to review response from the spawned process. However, the app that you launch has to have been written to provide such feedback. Some apps, such as render engines, have a parameter you supply on launch that will trigger progress feedback information as the process runs.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
