I'm going through a dynamics tutorial and although I have the basic scene set up as I was just playing around with things, trying to get a better understanding of how it all worked I ran into a question.
In the attached file's main_sim's SphereRBDObject node, when the X velocity is set to 1 and the sphere hits the ground, it rolls and abruptly comes to a stop. I know I can use the angular and linear thresholds to determine when it stops, but how can I make it so it gradually slows to a stop instead of stopping all at once? Thanks!
help with dynamics setup
2189 1 1-
- gswartz
- 24 posts
- malbrecht
- 806 posts
Moin,
you need to increase the solver substeps in your
You might also consider setting the rotational stiffness back a bit, so that the sphere can actually roll.
I hope this helps!
Marc
rigidbodysolver inside the main_sim. And then play with the friction values. You might also consider setting the rotational stiffness back a bit, so that the sphere can actually roll.
I hope this helps!
Marc
Good bye.
Good bye.
