particles to mesh and static object
   3286   2   0
hello.
I made a simple simulation with particles - torus jumps out from fluid tank (I used two keyframes - torus inside tank and after 5 frames torus outside tank). I used surface collisions fot torus. now I'm trying to export my object and splash to obj file. and I have a problem:
when I'm converting particles to mesh it comes into my torus because convertion creates a coves around every particle. so, the final mesh intersects my object.
could anyone help me, please?
Edited by glmr - March 12, 2017 18:07:37
You may want to look at the resolution of your collision mesh. If it is too low you get inaccurate collisions.
Edited by Enivob - March 13, 2017 12:25:42
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
so, the problem is solved with merge node connected to input2 with substract option
