Hair & Grooming
   2476   3   2
Houdini 16 Hair When I use Guide Brushes then I can not anymore change the options?
Moin,
Could you, please, elaborate? Which options don't you want to be able to change? The way Houdini works usually allows you to almost always change everything anywhere - only in cases where you have baked down some geometry for performance or other reason you may have to invalidate the cache.
So a tiny bit more help - like a video, an example file, a few screen captures - would go a long way helping people help you.
Marc
Good bye.
https://vimeo.com/207704687 [vimeo.com]
https://gumroad.com/alexeyvanzhula [gumroad.com]
If you use a brush to groom curves then change something upstream you will need to click ‘recache strokes’ for it to update.
