How to export the noise pattern as a displacement map in Houdini?
   4808   2   1
Is it possible I can save the generated noise in Houdini as a displacement or height map so that I can use it as a alpha mask in Zbrush and Substance Painter?
Sure, if your noise is created at the VOP/VEX level simply apply the texture to a grid and render the grid from top view camera.
If your noise is inside a COP network just drop down a ROP File Output and you can write the comp to a file or sequence on the disk. You can also fetch SOP values into a COP network and export that way too.
Edited by Enivob - April 12, 2017 21:08:29
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Hi Enivob, thank you so much
