fluid collision with each other
   4659   5   3
Heya, I want to collide two or more fluids collide with each other. I know I can merge the volume surfaces in the flip solver but in that case I can export only one merged fluid but I want to have the fluids as separate objects.
Normally I write the file out like in pic 2.
So what should I do in this case?
Edited by Kobar - April 16, 2017 22:43:02
houdini_fluid_test_01.hiplc (1.8 MB)
Hello.
This can be your solution:
https://www.sidefx.com/forum/topic/38134/?page=1#post-174430 [sidefx.com]
The first suggestion is the same I already had but not wanted: one flip solver makes two or more fluids merge together to one fluidmesh.
And the second one was done with a fake collision, mesh it, reimport it and use that as collision for the second fluid…
That can't be the workflow to go, can it?
You mean like this?
FluidCollide.hip (1.8 MB)
theres a stream attribute to split them apart based on the fluid source
Ahhh, perfect. Thank you! That's it
