Writing sequence of particle data to XML w/ Python + Element Tree
   3836   2   1
Hello! I’m trying to write out particle data (pos, scale, ID) to an XML file and have managed to get a single frame of data to write out correctly. However, I can’t seem to sort out how to iterate through each frame in Python and add the particle data per frame into the XML. Below is the python script, any ideas?
node = hou.pwd()
from lxml import etree as ET
geo = node.geometry()
root = ET.Element(“ObjectInstances”)
ET.SubElement(root, frame)
for point in geo.points():
pos = point.position()
scale = hou.Point.attribValue(point, ‘Scale’)
rotation = hou.Point.attribValue(point, ‘Rotation’)
ID = “Particle” + repr(hou.Point.attribValue(point, ‘id’)+1)
PosString = repr(pos) + “, ” + repr(pos) + “, ” + repr(pos)
RotString = repr(rotation)
ScaleString = repr(scale) + “, ” + repr(scale) + “, ” + repr(scale)
ET.SubElement(frame, ID,
Location=PosString,
Rotation=RotString,
Scale=ScaleString)
# Do the export
tree = ET.ElementTree(root)
tree.write(“/users/justinpuda/desktop/test4.xml”, pretty_print=True)
Check out hou.setFrame. Also you can fetch the playback range from hou.playbar. Then you can set up an inner loop that matches the playbar range.
http://www.sidefx.com/docs/houdini/hom/hou/setFrame [sidefx.com]
Edited by Enivob - April 19, 2017 12:47:04
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Thanks Enviob! I had found setFrame but due to my limited Python experience, I’m having a bit of trouble on the inner loop portion. Would I need to define the amount of frames from the hou.playbar call as a variable and then run a for/while loop? Or does Python have a way to do this with an if/else loop? I’m a bit more familiar with if/else loops than for/while loops from VEX scripting.
