Transfer texture from one mesh to another.....
   6859   3   1
I want to take a low and high poly mesh and take the texture color from a texture on the high poly and generate a new texture for the low poly and its UVs.
Bake texture rop node is what you're looking for. Apply the texture to one object using a basic shader, Set the other ovject as uv object on the bake texture node.
B.Henriksson, DICE
kahuna031
Thank you
Just to clarify a few things to get this working:
- Put the texture in the Principled Shader texture slot
- Turn on baking diffcolor in the Bake Texture ROP, since the default “Color” is for point Cd and just comes out white
