Houdini Engine plugin won't install
   6189   3   0
I'm running Windows 7, Houdini 16 and UE4.15
Unreal Engine is located at C:\Program Files\Unreal Engine\4.15\
When I attempt to install Houdini 16, I confirm that I want to install Houdini Engine for UE as well.
I don't receive any warning, the installation seems to go well but eventually no Houdini plugin gets installed.
What should I do?
It's possible that the installer didn't get your UE4 installation folder properly.. or has copied the plug-in files in a wrong folder.
You can install the plug-in manually by going to your Houdini 16 installation folder, and copy the HoudiniEngine folder in
C:\Program Files\Side Effects Software\Houdini16.0.XXX\engine\unreal\4.15
to
C:\Program Files\Unreal Engine\4.15\Engine\Plugins\Runtime\
The plug-in should then be detected when you launch UE4.
thanks for the advice!
Cheers
I don't bother with installing the plugin, instead I include it as part of my UE4 project and use the latest version from Github (hacking a few files to correct the location and version of my Houdini installation).
