How to subdivide in one UV direction only?
   6046   5   2
So to break down what I got, I have 12 wire lines (12 * 100 points) in a circle that I animate with some wind, I then lofted them, and to add some smoothness I subdivide them. It works, but I think it would be way more efficient to only subdivide in one UV direction only.
Would anyone know how to achieve this?
Thanks,
/Anton
procedural thinking - http://hexagons.se/ [hexagons.se]
Well doesn't your line control the U direction and the circle you are “lofting” control the V direction? Just subdivide the line before you skin or sweep.
Edited by Enivob - May 13, 2017 23:12:59
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
use a resample node to have more points on your curves - so the lofting has more geometry along the wire!
Greets,
Nico
True, I'll increase the points on the circle, thanks!
maybe use polypatch node.
Edited by wangguo - May 12, 2017 09:27:15
if you want to subdivide just one way of a part of your geo you can select the sides and add a polysplit node
