Hey guys,
this may or may not be an easy fix?
I exported and .abc out of maya to bring into houdini, but when I import it the UVs are missing?
I brought the same file into maya and the UVs are there. Is there something I'm missing or do I need a specific UV node?
Best,
Vish
.abc from maya missing uvs
5396 3 1-
- vishnu1024
- 73 posts
- madrenderman
- 129 posts
- tamte
- 9539 posts
if you want to inspect geometry attributes on alembic, you have to unpack it, so use unpack or convert node or both
but if you just want to apply material and render or see textures in the viewport, keep it packed until you really need to access geometry inside of houdini
- vishnu1024
- 73 posts
