Hi All,
I ran hgpuinfo and discovered that Houdini is not using enough of my GPU vRam. I have an 8GB 1070 card but Houdini only allocates 2GB. 2GB of ram is not enough to produce a high quality simulation.
When I try to leverage OpenCL on a production quality simulation, it always crashes. Now I can see why, it does not allocate enough ram.
Is there anyway to increase this allocation amount?
Even if I could allocate 100% of my vRam, 8Gb is not enough to do a movie quality effect, is it?
OpenCL Ignores My vRAM?
5491 12 0-
- Enivob
- 2658 posts
- anon_user_37409885
- 4189 posts
The Max allocation is for contiguous ram resource usage, the total possible available is above it at 8GB, though other resources may be using it when connected to monitors or rendering etc.
Sigh… for the uptinth time you need to use OpenCL CPU to access enough more ram for so-called production level effects. Are you sure you're not trolling?
- Enivob
- 2658 posts
I'm not trolling, this is news to me. I'm still trying to leverage this feature but Houdini keeps erroring out.
Are you suggesting I have to install something else beside Houdini to use OpenCL on Windows?
Also, in another thread, Jeff mentioned that OpenCL can use up to 4GB of ram. So my question is valid. If the developers says one thing and the reporting tool says another (2gb), something odd is going on…
Edited by Enivob - May 29, 2017 15:29:00
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- 4189 posts
- Enivob
- 2658 posts
- 4189 posts
Oh now it's understandable, frustration through ignorance!! OpenCL is for all devices - CPU, GPU, DSP, FPGA, Nvidia, Intel, AMD. It's all but one google search away:
https://en.wikipedia.org/wiki/OpenCL [en.wikipedia.org]
OpenCL is very very efficient code that will compile for the exact CPU features you are using, that is one reason is *better* than standard C++.
Really don't want to write how to turn it on again and again and again and again and again, so hopefully someone else will or you can just read all the other posts on how to.
- malexander
- 5287 posts
If you'd like to submit your hipfile with a bug report, we can figure out why it's either a) using more than 8GB, or b) using more than 2GB in a single allocation. Newer GPUs have virtualized their allocations so that it's possible to allocate more than 8GB in a single kernel invocation, but the 2GB single allocation limit still might stand.
Using OpenCL on the CPU isn't as bad as it sounds. OpenCL is just an interface to a compute device, and forces you to code in a way that's friendly to multiple cores/shaders/AVX/SSE/etc. Usually it gives a good boost even on a CPU, as the kernel is compiled optimally for that CPU type by the CPU driver, which can include AVX, AVX2, SSE1-4 instructions. When we compile Houdini we can't assume broad support for all of those CPU features.
- Enivob
- 2658 posts
Ok, so does this feature require me to learn yet another Houdinig coding language?
Does it work like a wrangle?
I see OpenCL check boxes all over the place, but no text input field for code?
Edited by Enivob - May 29, 2017 23:53:58
- malexander
- 5287 posts
- TheTex
- 7 posts
aRtey
There's zero need for the attitude, there's one result when searching for “OpenCL vram” and there's virtually no documentation of OpenCL in the help file.
It's a super reasonable assumption that ‘Max Allocation’ would be set to use your entire vram.
Edited by TheTex - June 4, 2017 02:43:35
- 4189 posts
TheTexaRtey
So, what's the point of your post?
- CiaranM
- 31 posts
goatI really don't think that it's unreasonable to expect a simple simulation to run on OpenCL through the GPU, especially if there is plenty of memory. The point is that we shouldn't have to fall back to CPU.
- 4189 posts
As this post appears to have become the go-to for OpenCL memory issues, and OpenCL has now been expanded across Houdini the answer is to set the environment variable:
The ‘1’ should mean 100%, though current of H17.5.239 / linux, it tops out at an allocation of 50%… i.e. a 11GB GPU will allocate 6GB and a system with 64GB CPU ram will allocate 32GB.
edit: it's funny to look back at this thread and see how the context has been lost…. damn interwebs!
export HOUDINI_OCL_MEMORY_POOL_SIZE=1
Edited by anon_user_37409885 - May 12, 2019 00:04:57
