Flood filling a selection
   7459   3   1
I'm trying to flood fill a selection and so far my method seems too round about. Is there a better method to fill the area between the selected polys in the picture?
The round-about method I'm using is selecting the edges with the Select tool menu ‘Cut Geometry for UV Layout’, then groupSop, then UVflattenSop, then use the ‘UV Connected Geometry’.
Would be nicer to just double click the area to fill it to the previous selection.
EDIT: I'm thinking of something like the paint bucket from MacPaint in the 1980's
Edited by anon_user_37409885 - June 3, 2017 20:44:58
Screen Shot 2017-06-03 at 8.25.00 AM.png (24.5 KB)
No need for a fancy setup - just hold down “H” while clicking inbetween.
Like holding “A” to make a “shortest path” selection with left click or middle click to do a loop.
This page is an awesome read:
https://www.sidefx.com/docs/houdini/basics/select.html [www.sidefx.com]
- Martin Egger
Student at Filmakademie BW
& Freelance FX TD
thank you! that does indeed work.
wonder why that isn't in the RMB menu…
Thank you so much martin-egger, works perfect with me, just what I was looking for, cheers!
Muhammad Faisal Shah.
