Hey all,
Super noob question.
I have 2 objects (OBJECT_01, OBJECT_02) with differing point counts. I'm trying to take the object with the greater point count (OBJECT_01) and divide it's points into 2 groups. The first group should have the same amount of points as OBJECT_02 with the remainder going into the second group.
I've put a group expression node on OBJECT_01 but can't for the life of me figure out what to put in the VEXpression field.
This closest I've got is: @ptnum > (“../OBJECT02/”, @numpt) but that's not working.
Any clues to what I'm doing wrong?
Thanks,
Chris
Reference external objects point count
4175 4 1-
- hellochristhompson
- 5 posts
- neil_math_comp
- 1743 posts
There's a VEX function named npoints [www.sidefx.com] that should help. For example:
Hopefully that's what you were looking for.
@ptnum >= npoints("../OBJECT_02")
- 5 posts
Hey ndickson,
Thanks for getting back so quickly! Unfortunately that doesn't seem to work. Using that code places every single point into the group.
I've attached a super simplified version of what I'm trying to achieve. Any further advice would be massively appreciated.
I need to take a course on VEX!
- neil_math_comp
- 1743 posts
Sorry, my mistake. To refer to nodes, the path has to be prefixed with
That seems to work.
The 1 refers to the input number, where the first input is input number 0, and the second input is input number 1, etc.
op:, e.g. op:../OBJECT_02. The less error-prone approach is to connect the geometry in question into the second input and do:@ptnum >= npoints(1)
That seems to work.
Edited by neil_math_comp - June 27, 2017 11:03:43
- 5 posts
