How to find overlapping prims for every prim?
   3823   1   0
I'd like to have an array integer attribute for every prim that stores the prim numbers of the overlapping/intersecting prims.
Is there any vex functions or sop node that does that?
In case not, how would you approach the problem?
I've no clues at all..
1. Create a unique integer attribute per primitive
2. Scatter points onto prims inheriting this attribute
3. Fire rays and gather non-negative results into an array and store this as an array attribute on the primitives
