Just airing out another little script for a shelf tool that quickly sets up non-linear (quadratic interpolation) blendshapes. Can be a handy technique for eyelids –
1) create fully closed and half-closed blendshapes, plug them into your blenshapes SOP.
2) Then select the blendshape SOP and run the shelf tool
3) select the half-closed shape as your ‘intermediate shape’ (the first prompt) and then your full closed shape from the second prompt
Hope it's useful to someone out there
blend_nodes = hou.selectedNodes() if len(blend_nodes) < 1 or blend_nodes[0].type().name() != "blendshapes": raise hou.Error("Please select a blendshapes node...") else: blend_node = blend_nodes[0] blend_list = list(p.alias() for p in blend_node.globParms("blend*")) idx = hou.ui.selectFromList( blend_list, message="Select intermediate shape...", exclusive=True )[0] first = blend_node.parm(blend_list[idx]) blend_list.pop(idx) idx = hou.ui.selectFromList( blend_list, message="Select final shape...", exclusive=True )[0] second = blend_node.parm(blend_list[idx]) t_parm_name = hou.ui.readInput("Please enter a name for the new drive parameter")[1] first_exp = '-4 * (pow(ch("' + t_parm_name + '"), 2)) + 4 * (ch("' + t_parm_name + '"))' second_exp = '2 * (pow(ch("' + t_parm_name + '"), 2)) - ch("' + t_parm_name + '")' spare = hou.FloatParmTemplate(t_parm_name, t_parm_name.replace("_", " ").capitalize(), 1, max=1.0) blend_node.addSpareParmTuple(spare) first.setExpression(first_exp, language=hou.exprLanguage.Hscript) second.setExpression(second_exp, language=hou.exprLanguage.Hscript)
