VEX array of structs
   2970   1   0
I'm a newbie with vex and I'm trying to create an array of structs in a wrangle node. I defined the struct in the outer code section as suggested here [forums.odforce.net].
my struct looks like this
struct node {
int pt;
int nbrs[];
After defining the struct, I have the following as VEX expression
node nd;
node array[];
// let's say we initialized the nd fields to some values
int pt = nd.pt; //works fine
int nbrs[] = nd.nbrs; //works fine
array[0] = nd; //seems to work fine
pt = array[0].pt; //nope
nd = array[0]; //nope
How do I handle situation like this one? Am I missing something on how to use struct in VEX?
Basically I cannot access the content of my array.
When I say it doesn't work I mean that the node turns red and throws an error
Error
The sub-network output operator failed to cook: /obj/new_version/tree/growing_alg/find_neighbour/outer_code/attribvop1
Warning: Errors or warnings encountered during VEX compile:
/obj/new_version/tree/growing_alg/find_neighbour/outer_code/attribvop1: Internal compiler error. (15,1).
Error: Vex error: /obj/new_version/tree/growing_alg/find_neighbour/outer_code/attribvop1: Internal compiler error. (15,1)
Failed to resolve VEX code op: /obj/new_version/tree/growing_alg/find_neighbour/outer_code/attribvop1
Unable to load shader ‘op: /obj/new_version/tree/growing_alg/find_neighbour/outer_code/attribvop1’.
Warning
Warning
Warning
Any ideas?
Thank you!
What I do is save an external text file with the struct code defined and use the include directive to reference it like:
#Include <C:/My External Vex files/My_Structures.h>
I noticed the issue a while back that you speak of, although I did mention it to support I don't remember if it was in the form of a bug/rfe or as an offhand comment with another bug/rfe.
Either way I tend to externalize all my vex code like functions/strucs in text files. Makes it much easier to read the various wrangles in my network.
But maybe you could submit a bug report - as it would be usefull to be able to just define the struc right in the wrangle itself.
Edit: I'm saying this not having looked at your code, because it was definitely an issue with the simplest defined structures, like only using ints and floats.
I see in your code though that one of your items is an array.
In Houdini arrays of arrays are not supported. So what I suspect is happening in this case is that your accessing an array within a struct - essentialy a heirarchy like an array of array - whereas your test assignment is simply acessing the array on the same ‘level’ eg. "array = nd; //seems to work fine"
Edited by BabaJ - Aug. 8, 2017 12:17:29
