timebar interactively stretching keyframes
   3884   4   1
Is there a way to interactively stretch keyframes on the timebar? the ‘visual stretch/paste’ doesn't have that grab and stretch feeeling.
Have you tried activating the Box Handle button in the Animation Editor?
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
does that work for you? it has no effect in the timebar.
Yeah, I wish Houdini's playbar worked like C4Ds.
The box handle does work for me in the Animation Editor. I did not know you could edit keyframes in the playbar. I guess I'll have to look into that.
Figured it out. the MMB on the little bit inside handle - without a highlight showing that you've grabbed it and being so small, it's very easy to make a mistake and miss it which makes the selection disappear.
