HConfig loaded ?
2800 9 1-
- _Christopher_
- 767 posts
- BabaJ
- 2169 posts
- _Christopher_
- 767 posts
- BabaJ
- 2169 posts
That I don't know, maybe someone else does know.
But probably what most people would ask, is why?
hconfig -h will give you all the info you need to know in what it can do for you.
But to continue down the line your interested in you probably have to step outside Houdini and start with something like:
https://en.wikipedia.org/wiki/Command-line_interface [en.wikipedia.org]
- _Christopher_
- 767 posts
- BabaJ
- 2169 posts
Here's a couple more links that might help…
Command Line Interface [en.wikipedia.org]
and
Shell
From this second link the following may give you some hints…
and
Shell
Most operating system shells are not direct interfaces to the underlying kernel, even if a shell communicates with the user via peripheral devices attached to the computer directly. Shells are actually special applications that use the kernel API in just the same way as it is used by other application programs. A shell manages the user–system interaction by prompting users for input, interpreting their input, and then handling an output from the underlying operating system (much like a read–eval–print loop, REPL). Since the operating system shell is actually an application, it may easily be replaced with another similar application, for most operating systems.
- _Christopher_
- 767 posts
- BabaJ
- 2169 posts
Hmm….
Shell
What I suspect is that the houdini console is a compiled shell.
It's a compiled program that has included - in the case of a windows system, the same functionality of the windows console and then some, like hconfig.
Which if this is the case, it's not really looking anywhere for hconfig because that functionality has already been built and would be seen in the source code files used to compile the houdini console.
It may be that SideFX used the windows console as a template and modified/added to it for us Houdini users for specific purposes that could not be obtained with only the windows console, save us having to write out our own library of .cmd/.bat files.
The reason I say it might be compiled is because of this guy who wanted to add functionality to the windows console that was not there…so he created one which is compiled. Which is why I think SideFX did something similar.
https://scotch.io/tutorials/get-a-functional-and-sleek-console-in-windows [scotch.io]
Although this guy used Git Bash…SideFX may have done something similar but with a different source, like maybe Bash alone?
Here's another link that kind of gives some more crumbs on the matter…
https://superuser.com/questions/1053633/what-is-git-bash-for-windows-anyway [superuser.com]
Shell
- BabaJ
- 2169 posts
for some reason my linking is not working…
https://en.wikipedia.org/wiki/Shell_(computing)
Shellwas suppose to point to
- _Christopher_
- 767 posts
