Right-click menu in Viewport
   2237   1   1
When you select a node, and press enter in the Viewport, if you right-click, you have have access to a menu.
How do you create / modify that menu for HDAs?
Thank you,
Ryuji
Pretty sure this menu isn't accessible for HDA's and there's not a lot of customizability around the viewport to allow you to work around it. Network editor's rmb is probably your best entry.
B.Henriksson, DICE
