Default values for function arguments in vex snippets error
   5156   5   1
The snippet
int test(int a;int b=2)
return a+b;
returns invalid default value for parameter b error
Is there a way to have default values for function arguments in vex snippets?
int test(int a,b)
int Result;
c = 2;
if //code on this line for condition that is met to use default
Result = a + c;
else
Result = a + b;
return Result;
Edited by BabaJ - Oct. 30, 2017 10:14:41
if you expect it to work like python and being able to just omit b to get the defaults, then it's not automatic
you can however create the representation of the function with just a and use default value for b inside
like this:
int test(int a;int b)
    return a+b;
int test(int a)
    int b = 2;
    return test(a, b);
printf("%g\n", test(1)); // returns 3 (1 + default 2)
printf("%g\n", test(1,1)); // returns 2 (1 + 1)
tamte
like this:
    return a+b;
int test(int a)
    int b = 2;
    return test(a, b);
That's exactly what i did)
Still it's strange that this example errors out in snippets
taken from http://www.sidefx.com/docs/houdini/vex/lang [www.sidefx.com]
surface
noise_surf(vector clr = {1,1,1}; float frequency = 1;
           export vector nml = {0,0,0})
    Cf = clr * (float(noise(frequency * P)) + 0.5) * diffuse(normalize(N));
    nml = normalize(N)*0.5 + 0.5;
lizardstailz
I don't think you can define a shader in the snippet
snippet already runs within the context function
so you can use just normal VEX functions, which don't have default values for arguments
Edited by tamte - Oct. 30, 2017 17:25:16
Ok, thanks for the answer)
