Houdini crashing when using Render state
   4387   5   1
Hi SESI.
I have suffering many inestabilities with the Render Operator, using it like a volatile render render operator, sometimes when i activate it Houdini crashes, the output in the terminal says:
(sent by pid 0)$ 13462: Fatal error: Bus Error
Saving application data to /tmp/pablo.13462.hip
Using Houdini 8.0.499 Linux with Ubuntu 5.10
Anyone with the sames problems?
Un saludo
Best Regards
Pablo Giménez
Could you post the contents of your /tmp/crashlog_pablo file?
edward
Yes, of course:
http://personales.ya.com/lisux/crashlog_pablo.txt [personales.ya.com]
Hope this helps.
Un saludo
Best Regards
Pablo Giménez
Any light about this error?
It occurs to me very often.
Can it be related to the graphivs system?
I am using GeForce FX 5200 with Ubuntu and Nvidia drivers version 76.67.
Another crash log:
http://personales.ya.com/lisux/crashlog_pablo2.txt [personales.ya.com]
Un saludo
Best Regards
Pablo Giménez
No idea. I couldn't reproduce it and the crashlog unfortunately isn't much help. For some reason, it crashes on redrawing the viewport.
edward
Yes edward i suffer many problems when Houdini needs to redraw the viewport, sometimes i press Ctrl+RMB to open the PolySplit SOP options, or another popup menu, it is stalled over and i need to change the view size using Space+t to force a complete redraw and eliminate the popup menu from the viewport.
Do you think that these problems are more related to the graphic card rather than Houdini?
Un saludo
Best Regards
Pablo Giménez
