Hi all.
Maybe i am making a stupid midtake, but why in the hip supplied the second transform operator handle don't align correctly using the object transform.
The translates transforms are good, like you can seein the handle parameters, but the rotation thanforms are always zero, and this is wrong.
So the handle follow the object, but don't rotate to align to it.
http://personales.ya.com/lisux/rotateProblem.hip [personales.ya.com]
Handle orientation error?
4298 6 1-
- lisux
- 581 posts
- lisux
- 581 posts
- edward
- 8080 posts
- lisux
- 581 posts
edwardIf you press p you open the parameters window, or not?
I thought it was happening for me too but then I changed around the handle alignment by hitting p in the viewport. It fixed itself and I couldn't reproduce anymore.
What do you set up there to solve the prolem?
If you use for example, edti SOP you can't modify the handle transformation, so this option doesn't work.
Un saludo
Best Regards
Pablo Giménez
Best Regards
Pablo Giménez
- edward
- 8080 posts
- lisux
- 581 posts
- edward
- 8080 posts
