Hi guys,
I am trying to figure out how to blast or not blast selected faces in a loop based on the measured area.
For example, I am trying to blast a group selection of faces only if the selected faces area sum equals 4.
I could not figure this out so far.
Current process
1, Select faces in a group node
2, measure groups face area
3, promote the area attribute to areaSum to a new detail class, promotion method to Sum
4, blast the selected faces and unselect
5, Merge them back together
6, add a split node and try to split them based on if the attribute areaSum=4 so they can go separate
ways down the network if there is a selection equalling areaSum 4.
I have tried different expressions like “if(`detail(”../blastSelected//“, ”areaSum“,0)`==4)” or
@areaSum==4
Any ideas
Blast selected faces based on measured area sum
2847 2 1-
- shamatha
- 3 posts
- vusta
- 555 posts
- shamatha
- 3 posts
Hi Vusta,
Really appreciate your reply it helped me a lot . I adjusted the logic slightly like you mentioned.
I have uploaded the file with the network . Do you think this it the best approach in the way I have set it up.
I am having a play at reproducing parts of the procedural hallway tool I seen on go procedural vimeo.
Cheers mate
Cheers mate
