Hello all,
I need to add paths to the following environment variables:
HOUDINI_PATH
HOUDINI_MENU_PATH
HOUDINI_OTLSCAN_PATH
The problem I have is that I want to do this using global environment variables on Windows rather than the houdini.env file. I have found currently, if I attempt this, it breaks Houdini quite badly because it messes with it's environment setup procedure. Is it even possible without using the houdini.env file?
What does the environment setup do?
2323 2 1-
- lloydwood
- 107 posts
- lloydwood
- 107 posts
- buki
- 1773 posts
just add the extra stuff at the end of each line, something like this:
HOUDINI_OTLSCAN_PATH = $QOTL/base;$QOTL/future;$QOTL/experimental;@/otls
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
