Cone Constraint Problem
   3250   7   1
I have a problem with my cone constraint network.
I will recreate my project to simply visualizate to explain more clearly
So first of all, I have 2 walls, each wall has own conestraint network, everything is merged together.
I selected both nodes with geo then I disabled display geos.
so I get something like this - cone constraint
Next I will talk about 2nd input in merge node because this one works ok
as we can see the pic above has correct ‘object link’, but when I tured off that and turned ‘object link’ for another wall, its seems to be linked to my 2nd input in my merge.
On next picture we can see small dots between two walls - those dots are coneconstraint for wall 1, but they are moved because this is linked to first input for merge node (2nd wall).
Is any way to fix this? I will be glad for any help. This is very important for my final project but I am stuck.
Thank you
Would be maybe easier to understand if you share the file, too?
matthias_k
There you go
File.hipnc (549.3 KB)
Do you mean the attributes set in “constraint_attribs..” primitve wrangle in your wall objects?
Which are then promoted to the dop net
matthias_k
honesty, I don't know what you're talking about
In my previous posts I described a problem which can be checked by enable the option called ‘Show Object Link’ under ‘Guide Option’ Tab for ‘conetwistconrel3’ and ‘conetwistconrel1’. If we check only 2nd input for merge node, its working correctly, but the first input doesn't. I think this happen because the first input see the second input and connect all coneconstraints together.
I will be in a big trouble if I can not fix it
Edited by Bartolomeooo - Feb. 9, 2018 09:48:45
what are you doing to get the points, they are only visible if you have not set output to the last node, or at least not before last “glue_rbd_Wall”
houdini 16.5.323 here
53983_01.mp4 (2.8 MB)
Ahhhh, I got it :-)
(hopefully…)
it's coming up in 16.0.736 here, maybe simply update your version
matthias_k
Ahhhh, I got it :-)
(hopefully…)
YES! works. oh my god, I didnt think it could be a version issue
Just I needed to tweak a density value and glue constraint to achieve correct result, but yeah it works!
Thank you so much for your help
