delete interior faces
   10586   3   1
Hey,
So I have an enclosed object with interior faces (from a cookie SOP done earlier). I am not sure if I am overlooking a simple way to delete these interior faces procedurally. Any suggestions??
- Spencer
Can you use Group SOP to see if this allow you to group back-facing primitive/points via Normal?
HTH,
Alex
In the Cookie, you can turn on Groups which will give you a single group for inside and outside of each object which you can then just delete. Alternatively, you can select User Defined for the operation and only keep what you want, which is even easier )
Peter B
Peter Bowmar
____________
thanks Peter, I forgot about that, thats what I was looking for.
