Looking for help to troubleshoot an issue with VEXpressions.
It seems that every time I try to add something to the expression field or via the expression editor, it simply does not update my node (in this case a point wrangle). The only way I can get my script to update the node is to copy my expression and paste it in a fresh node. I am a total n00b, so figure i'm missing some super simple and obvious checkbox or?
Oh, btw. 16.5 on macOS
Thanks.
VEXpression changes does not update the node
2003 1 1-
- Virgil Kastrup
- 1 posts
- neil_math_comp
- 1743 posts
Does pressing Ctrl+Enter work when you're editing it in the parameter pane? I usually just click somewhere in the network editor and it updates, (as long as the viewport is visible and Auto Update is on, as opposed to Manual, in the lower right corner of the Houdini window).
