Hi guys
question for you
i am making a tool to generate a specific type of assets in clusters, and i would like to be able to randomize certain fields in those assets(like for instance, randomizing the offset in a mountain sop) but not based on points or number of points, or anything related to those assets in specific since im using a copy-sop all the copies have similar stats. How can i get completly random values for those? I was thinking about using the world position of where they are created to use for the rand() but i have no idea on how to do that. Please help
thanks
randomizing fields using completly random values?(like world position?)
2347 2 1-
- mulafraga
- 30 posts
- old_school
- 2540 posts
Incorporate world position in to point position for random seed generator…
One way is to promote a vector parmeter and use the vorigin() or more specificialy vtorigin() hscript expression to crack the world transform to this parent object.
tx: vtorigin(“”, “../”)
ty: vtorigin(“”, “../”)
tz: vtorigin(“”, “../”)
where “” is world space and “../” is my parent's position or my object container in this case.
The trick is knowing that vtorigin() returns a vector and you can use the square brackets to index in to the result of the vector counting from 0.
You can also use vorigin which returns an array of 6 elements tx-tz and rx-rz where you use to to fetch the translates and rotates for even more randomability.
See the example file along with the same notes above as a comment in SOPs beside the Attribute VOP.
- mulafraga
- 30 posts
