How would one go about extracting an embedded image file in an HDA? Is this possible? I've been trying to find edu material about this online but there doesn't seem to be too much of any documentation on this (that I could find).
Thank you for any help!
Extract embedded files from HDA
6449 8 1-
- 9krausec
- 66 posts
- goldfarb
- 3465 posts
- 9krausec
- 66 posts
goldfarb
if you mean saving a file from the Extra Files area then you can select the file in the list, and at the bottom right of the Type Properties dialog > Save as File
Any idea how to do that through HOM - Python by chance? I'm trying to query a list of internal HDA files and if those files are images I wanted to extract them out of the HDA using Python.
Having a hard time finding documentation on how to handle an operation like this (at least where I've been looking for the information).
Thank you for the reply.
- jsmack
- 8223 posts
You may find these classes useful now, and in the future when scripting with HDA.
http://www.sidefx.com/docs/houdini/hom/hou/HDADefinition.html [www.sidefx.com]
http://www.sidefx.com/docs/houdini/hom/hou/HDASection.html [www.sidefx.com]
- 9krausec
- 66 posts
Thank you. I'll keep on trying, but I'm still having some issues getting my head around this. For instance-
So in the above, I can ask if a section exists. I can return a names of sections a strings… But I'm having a hard time figuring out how to return a section object and work on it. Even if I figured out how to return a section object, I'm not finding any “write out contents of section” in the section documentation.
I'm also confused why there is a “definition()” method inside of the HDASection class as would the the HDASection be inside of a definition?
EDIT: I'll also be happy to take any suggested learning resources on this too if there are any recommendations. Docs only make so much sense to me without seeing the application.
t = hou.node('/obj/customHDA') #t has section 'kittens.jpg' in it t.type().definition().hasSection("kittens.jpg") #Returns True for x in t.type().definitions.section(): print x #returns the section name as a string
Edited by 9krausec - April 23, 2018 14:30:43
- jsmack
- 8223 posts
- 9krausec
- 66 posts
Alright, I'm slowly figuring this out with all of your help. I was a bit confused on the syntax of it all, but here is what I have going so far… “saveSectionToFile” is from the docs..
Attached is the original jpg as well as the extracted. The original comes in at 50.6 KB, the extracted at 50.8 KB. The original isn't opening up as a jpg picture file should open up.
If anyone would mind explaining to me why the extracted jpg picture isn't opening up, that would help out a lot. I tried all the 3 compression types without any success-
Gzip
Blosc
NoCompression
Thank you all for any help in getting me to understand this better.
EDIT: I'd like to add that Photoshop posts with the following warning message when attempting to open the kittensExtracted.jpg
“Could not complete your request because an invalid DQT JPEG segment QTable number is found (it must be < 4)”
def saveSectionToFile(section, file_name): '''Given a section, save it to a file.''' section_file = file(file_name, "w") section_file.write(section.contents()) section_file.close() t = hou.node('/obj/hdaObj') td = t.type().definition() if td.hasSection('kittens.jpg'): saveSectionToFile(td.sections().get('kittens.jpg'), 'C:/Users/clayton.krause/ Desktop/tmp/kittens.jpg')
Gzip
Blosc
NoCompression
Edited by 9krausec - April 23, 2018 16:04:38
- goldfarb
- 3465 posts
- 9krausec
- 66 posts
goldfarb
you'll need to use Binary:section_file = file(file_name, "wb")
Thank you for that! I wouldn't of picked up on that being the issue for a long while…
Alright gang, thank you for all the help! I try to ask stupid beginner questions sparingly and look through the docs / research before asking as best as I can! I'm just getting familiar with HOM coming from an intermediate Python background (I say intermediate because I've used a lambda function before, lawl).
Anyways, thank you for your time! Appreciate all the help here.
