I'm experiencing different behavior of Point Wrangle and Point VOP when they should be doing the same thing. In particular, I create a curve and using PolyFrame I create its tangent vector. Then I want to move each point of the curve by its tangent vector, when I do this with Point VOP it works as expected but when using Point Wrangle I get some garbage.
I have attached an example scene and I'm using Houdini Apprentice 16.5.439
Problem with using PolyFrame output in PointWrangle
2164 3 0-
- Kostra
- 9 posts
- anon_user_89151269
- 1755 posts
- Kostra
- 9 posts
- BabaJ
- 2164 posts
Not stupid at all. Just a misunderstanding of what your looking at.
Your not specifying a variable, your ensuring that you are accessing the desired attribute, which is not the same as a variable.
You also cannot compare a working environment - in this case data, such as attributes, between any number of nodes;
With a programming language.
Your not just dealing with the syntax of vex - but how that must be structured/used in the context of the hip file.
