Python Error while dividing: TypeError: unsupported operand type(s) for /: 'int' and 'NoneType'
   8640   3   2
So I'm working on a tool that requires me to do some divisions of variables. I ran a test version in the Python Shell window and it worked just as I expected but when I run it in my Python node I get an error when I apply it. Here is the code and error
node = hou.pwd()
geo = node.geometry()
hairs = list(geo.prims())
hair_count = len(hairs) - 1
node_percent = hou.node("/obj/geo1/Percent")
percent = node_percent.parm("Percent")
threshold = int((hair_count / percent) / hair_count)
Error:       Python error: Traceback (most recent call last):
File "<stdin>", line 11, in <module>
Does anyone have an idea why this would happen?
Thank you in advance
Justin Rhoades
If the node with path /obj/geo1/Percentdoesn't have a parameter whose token is Percent, node_percent.parm("Percent")would probably return NoneType. Make sure you're not mixing up the parameter's token and label. You can hover over a parameter's label to see it's token in the help tooltip. Hopefully that's what you're looking for.
You didn't evaluate the parm either. If you evaluated it first, you would have caught the exception earlier as “NoneType has no attribute ‘eval’”
Thank you both. You were absolutely correct on these issues. Thank you for the quick reply sorry I was slow to respond
