How to create voronoi on curved surface without inner geo
   3285   4   1
I have a simple question but after hours researching i couldn't find an answer yet….. i'm trying to create a voronoi curved surface but after trying this approach: voronoi fracture/blast-inside group/divide-remove shared edges i get the voronoi cells on the curved surface but each cell is disconnected. I also tried tweaking the “fuse” setting in the voronoi sop to connect all the cells and add a fuse sop in the end but for some reason the cells vertex never get fused.
Does someone knows how to create a voronoi curved surface without those straight edges from the original geo?
I'm attaching some images as references to i i'm looking for as the end result. Any help is appreciated.
Cheers
Attachment Not Found
I made an attempt in the attached hip file, maybe it can help you get closer to your end goal
facet_vornoi.hipnc (164.4 KB)
I went a little bit further and used pop grains inside a dop network to try and smoothly interpolate polygons over the above wireframe. I'd be interested to know if there was an easier way.
facet_vornoi_02.hipnc (344.6 KB)
Can I just say, this is freakin brilliant
You can check off “create inside surface” on the voronoi node. Then it will only shatter the input geometry.
this was my attempt:
VoronoiSphere.hipnc (157.4 KB)
