One sided objects
   2289   2   0
I have an object that's strangely partly invisible from one side and partly from the other. I.e. when rotating the camera around part's of the object appear and disappear depending on which side they're viewed. When displayed as wireframe, everything is there. The object is imported from sketchup, and I've understood sketchup is notorious with f*king up uv's etc. But i cannot fix this even with deleting all point, vertex, primitive etc attributes.
Any ideas?
Your viewport near/far clip plane may need to be set differently.
You could also try spacebar + h then try rotating.
Sometimes viewport is a bit glitchy and you have to ‘click’ around a bit and/or close current scene view and make a new one etc.
If your worried about the geometry itself…to assure yourself you can do a quick render.
Sounds like it might be an issue with the Normals.
>>Kays
