Edge Loop selection not working
   2011   1   0
I created a vase using a Curve and Revolve which I then converted to a Polygon.
Edge rings (Double-MMB click) works fine.
Selection of Primitives and Points also works as expected.
For some reason I can't select edge loops on the resulting geo.
It works fine on a Grid, but I just discovered that it also does not work on a Sphere (Polygon Mesh)
Any help and/or explanation is appreciated.
bottle_problem_001.hipnc (60.5 KB)
hi,
did you test the “clean sop”?
http://www.sidefx.com/docs/houdini/nodes/sop/clean.html [www.sidefx.com]
