Hi
Please help me figure it out, let me describe my example.
I have modelled wood plank and generated UVs for it.
Now I want to copy the plank to points to create for instance wooden floor or fence.
Then to make it look more natural I want to randomise each copy by offseting UVs by random number per copy (or per UV connected geo) so that each planks get different area of texture map
I know it can be done in two ways:
- copy stamping
- for each loop
I tried to do it both ways but I failed to do it correctly.
Can someone help me with that? Maybe provide hip file with example of both ways.
Thank you in advance.
Help needed, How to randomise UVs on packed geo per copy? <SOLVED>
3259 4 0-
- McKormick
- 17 posts
- McKormick
- 17 posts
- tamte
- 9380 posts
if you modify UVs or any attribute inside of packed primitives per copy, you'll lose the advantage of instancing
so rather than doing that, just do it in the shader
- add any id attribute per packed primitive like i@plankid for example
- then access it in the shader using Renderstate VOP like integer packed:plankid use that to randomize the offset
- then just drive UV Transform's trans input to modify uvs per unique plankid
see example
see example
Edited by tamte - Aug. 5, 2018 07:04:21
- McKormick
- 17 posts
- bretik1
- 8 posts
