Convert Fogvdb to Polygons
   3045   1   1
Hello - I was wondering if maybe my system has some glitch or something.
It seems I can't convert a Fog vdb to polygons/polygon soup with the vdbconvert node or convert node.
Thought I've done it in the past, but maybe I remember wrong and this has to be converted to a surface first?
Edited by BabaJ - Aug. 9, 2018 10:17:44
VDBfog to Polygons.hiplc (327.1 KB)
To create a mesh set from a fog volume, internally it must first build a level set which requires values on both sides of the interface. Hence, need to increase the “isovalue” to a small value above zero to get a result. make sense?
Edited by jbudsberg - Jan. 4, 2019 20:00:23
