Import subtnwork geometry into other networks
   7873   2   3
I'm currently working on a scene where I import and fbx file wich I want to move to a geometry network wich I can't.
I can't the way to do what I need.
Is there a way to use de data of the subtnetwork to work in other neteorks (geometry, dop, sop, etc.)?
Screenshot (108).png (161.3 KB)
And why not use the an “object merge” node to grab geo/data from anywhere ?
Use a blank/geo with an object merge inside,
Then in the “object”:
I assume inside your subnet you have multiple objects… so in the object field you need to:
1. write “/obj/subnet2/*” in the Object Merge to merge all geo available inside the subnet
2. create a bundle and put manually the subnet geos then use “@mybundle” in the Object Merge
3. create an smart bundle using a filter “Object:Geometry Only” using /obj/subnet2/* as the pattern. Doing so you will merge only the geos
4. I assume you can create a group too, but I don't know this workflow much
Edited by NNois - Sept. 21, 2018 03:33:10
