mirror problems
   4359   3   1
Hello again everyone, problem with the mirror operation. Trying to mirror a leg rig and it goes all wonky on me (even though the pre-mirror operation template looks perfect). Any thoughts?
file attached
leg_rig.hip (222.9 KB)
~the most important things in life aren't things~
Works fine for me. Make sure you select a Target CHOP Net. If you don't then Houdini can't Mirror/Create nodes for your KIN Solvers.
still not working… check out the hip and see if I'm doing something wrong. It looks like it is copying all the bones properly, but there is some problem with the goals. Maybe some settings in my version of houdini? Frustrating!!!
leg_rig.hip (497.2 KB)
figured it out… I had “read only pretransforms” highlighted in the objects and geometry in the main settings.
