Hi ,
I am trying to convert a basic VOP setup to VEX and I am facing some differences in the output using reflect as VOP node,and while used as a VEX function,In the attached file Reflect in VOP is causing the object to change direction smoothly based on the force used after hitting the ground where as in VEX the change is sped up and object in not reaching to the ground,Not sure where I went wrong.
issue between reflect VEX function and VOP node
1798 2 0-
- MarXindia
- 34 posts
- jsmack
- 8177 posts
There were two issues with your vex code.
Here is a fixed version of the code:
- The non-reflect state was adding the force to the existing force, whereas in the attribvop, it was passing through unchanged.
- The if statement's actions were the reverse of how it was in the attribvop.
// Explicit prototypes vector @P; export vector @force; float @radius; int switch = @P.y <= @radius; vector dir = @force; vector nml = set(0,1,0); vector rdir = reflect(dir, nml); @force = select(switch, rdir, dir);
- MarXindia
- 34 posts
jsmack
Here is a fixed version of the code:// Explicit prototypes vector @P; export vector @force; float @radius; int switch = @P.y <= @radius; vector dir = @force; vector nml = set(0,1,0); vector rdir = reflect(dir, nml); @force = select(switch, rdir, dir);
thanks alot jsmack,that makes sense and works
