groups to polygroups
1855 2 1-
- somename
- 2 posts
- Enivob
- 2658 posts
I have not tried it in Houdini 17, but in previous versions, the .OBJ export did not support that. There is a script that leverages the Post-Write event field of the export ROP. Place the code in the script field, change the code type to Python and when the export is issued, the code will re-write the resulting .OBJ file to produce a new .OBJ file with material assignments for detected groups. These materials are generally what importers look for.
https://forums.odforce.net/topic/25214-post-processing-an-export/?do=findComment&comment=146948 [forums.odforce.net]
Edited by Enivob - Nov. 12, 2018 22:03:50
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- somename
- 2 posts
