I was wondering if it was possible to output directly heightfields to Maya using Houdini as a compositor in the background.
The idea is to be able to project Maya geometry onto a heightfield and preview that in Maya on the displacement node.
Outputing 2D volumes to Maya Displacement
2448 1 1-
- Klass
- 11 posts
- juliap
- 146 posts
Your best bet is to export the height and color map, and then bring it in as a displacement material with a file texture, or just convert the whole thing to polys in your asset.
The maya heightField node can't be used with a live connection from a plugin node - it expects the displacement input to come from a native maya shading node, and calls back directly into the node for texture evaluation, using methods that aren't available in the api to override.
Edited by juliap - Nov. 19, 2018 13:50:53
