I'm using the v2 beta version of Houdini Engine 16.5.371, with Unity 2018.2.1f1
When I switch my Unity project to C# 4.0, some essential features stop working : I can't edit curves anymore (no GUI show off in the scene viewport, neither do the grey points and green lines of the curve).
Has this issue been fixed in a further release of Houdini or Unity ? Is there a workaround in this version ?
[Solved] Houdini Engine Unity not working with .NET 4.0
3240 4 1-
- Valentin BESSON
- 5 posts
- Enivob
- 2659 posts
That is funny, I was just working my way through the pipes HDA tutorial for Unreal 4.2.1 and experienced the same thing. When I drag curve1 into the Editable Node field of the type properties and save and reload the HDA inside of Unreal, I don't experience any editable curve at all, just the mesh.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- seelan
- 571 posts
- Enivob
- 2659 posts
- Valentin BESSON
- 5 posts
Ok I confirm: issue fixed with the Engine packed with Houdini 16.5.663, if I switch to 4.0 before importing the hengine package.
ALSO the curve editor didn't show up until I reset Unity's layout.
Just a little warning : when importing the hengine package, a warning is thrown. Also,after importing the package, don't forget to close and restart your unity (in order to trigger a recompiling, I believe) so that hengine scripts do their job properly.
Edited by Valentin BESSON - Nov. 27, 2018 09:59:30
