node.asCode()
   2187   1   0
When I write node.asCode() in python shell it returns this message:
File “<console>”, line 1, in <module>
NameError: name ‘node’ is not defined
how can I access node.asCode() within Houdini 17?
your node variable must be of type hou.Node(), from the error it seems you haven't even defined the node variable
create for example geo node at obj level, leave it at default name geo1
then run this
node = hou.node('/obj/geo1')
node.asCode()
or directly this
hou.node('/obj/geo1').asCode()
