DOPS: interwirecollision and wirewidth
   4476   3   1
hi,
I have to colliding wires and it seems to me that not the added width is used, but the averaged of both. I created a very simple test to show this. Is there some way around this?
martin
simple1_d2.rar (13.5 KB)
The problem is with the understanding of the “WIDTH”. The width is the diameter of the wire or hair, but when you create a circle to represent that hair, you use the width for the radius. So it's twice as big as it should be. The solution is to use $WIDTH/2 in your copy SOPs.
Thank You very much!
Martin
That's a very cool example of using the “virtual” wire radius in DOPs, btw, SESI should rip it off and make it an example file!!
Peter B
Peter Bowmar
____________
