Enabling/Disabling bind export in point VOP
4843 4 0-
- mrCatfish
- 738 posts
I have a VOP network that has a bind export. Sometimes I want to export the attribute, and sometimes I don't, (using a toggle). I can't see any way to do this… I tried an elaborate if statement in the callback with opwire and unwires, but it doesn't work, (although it works in the textport).
I'm petty sure this is possible, I just don't remember how.
Sean Lewkiw
Machine FX - Cinesite MTL
- bonsak
- 459 posts
- mrCatfish
- 738 posts
Yup that worked.
I'm putting the workflow here for posterity's sake.
- In the hscript callback of the button:
opdef:.?flip `ch("exportN")`
- In the node tab I added the node I will be modifying the the “editable nodes” parm
- In the “extra files” tab I added a new hscript section called “flip”
- The code for that is:
if ($arg1 == "1") then opparm ./rotate_normals vex_outputmask ("*") else opparm ./rotate_normals vex_outputmask ("* ^up") endif
Edited by mrCatfish - Dec. 14, 2018 10:41:00
Sean Lewkiw
- tamte
- 9548 posts
rather than making editable nodes and callbacks which will make your HDA very unflexible especially during updating or if you want to animate your toggle
you can directly reference your toggle value in the Export Parameters parm like this"
attached example
`ifs(ch("exportN"),"N","")` `ifs(ch("exportup"),"up","")`attached example
- Sifis
- 10 posts
tamte
you can directly reference your toggle value in the Export Parameters parm like this"`ifs(ch("exportN"),"N","")` `ifs(ch("exportup"),"up","")`
attached example
Thank you Tomas, I always had a hard time to selectively export attributes from VOPs. Very useful trick.
