Rotation and translation of node
   2035   3   0
If I rotate/translate a specific node, the translation/rotation takes place only for UV, not for the geometry. It's only for two specific nodes, all other seem to work quite right. Any idea what I'm doing wrong?
Best wishes,
Thomas
are you by any chance using UV Transform SOP instead of Transform SOP ?
I don't use a Transformation node. I'm NOT in the geometry node, but I'm on obj level and use the “Transform” tab to transform and rotate.
Best wishes,
Thomas
Oh, when in object merge, I normally use Transform “Into this object.” This was the problem… I changed it to “None.” Now it works! Thanks though!
