Build lighting
   3132   1   0
When I build light for static mesh and play
I have problem, baked light on my instansing look bad
but if I don't tune on game mode it look good
Unreal Engine 4.21.1
Houdini Engine 17.0.459
Edited by unitmotion - Jan. 13, 2019 09:03:57
Light.zip (5.1 MB)
bild_test.hda (18.7 KB)
Which Unreal Engine version is it?
Once you baked the hda out, you should have something like a Blueprint with instance static mesh component and a static mesh. Those assets would then be native Unreal assets. If you set the settings on those correctly it should be all good.
