Is it possible to combine scatter methods in HeightField_Scatter?
   1503   1   1
Newbie here! I'm trying to figure out if it's possible to scatter using “Per Point Count using Source Points” but also respect the incoming mask with “By coverage using Mask Layer.”
I have scattered trees on a HeightField I want to scatter bushes around, but I want them to also remain within my masked area used for the tree scatter. I ended up combining some masks created with circles placed at the tree points scaled for an inner radius and outer. It works but it seems it would be much simpler to be able to combine the scatter methods within the HF Scatter node. Am I missing something?
what I want to do:
Second question!
How would I display both a HeightField and reference geometry? I know I can make template the geometry, but I want to view it as solid rather than wireframe.
Edited by noshuajoble - Jan. 16, 2019 17:46:04
I want to know this, too. but anyway, I guess I can delete the points outside the mask after scatter, though.
