How to render RBD with motion blur?
   4250   1   0
Hi all, I'm trying to render rbd simulation with motion blur, but nothing happend. Please tell me how to achieve this.
Thanks in advanced for helping!
I guess You used transformation motion blur, and Your object is inside geometryOBJ. That means Your object is not moving at all, but the points are moving. Right now I have no idea how to get a simulation to the object level, but in Your case You could use either the deformation motion blur or append a trailsop (set to compute velocity) and use the velocity attribute blur.
I think the fastest option would be transformation motion blur, but I know no way until now how to use it with rbd. May be someone else can help. But the two other options work quite well
cheers
martin
